I need to find a way of measuring the differential pressure between the inlet and outlet of a heat exchanger used to heat pickling acid (10% hydrofluoric acid and 25% nitric acid). Inlet pressure is approx 2-2.5 Barg (30-35 PSI) and pressure loss is approx 200-250 mBarg (0.3-0.35 PSI).
I've looked at various diaphragm seals but all I've found are suitable for gauge pressure only, not diff pressure. As the pressure drop is quite small compared to the swing of the sensors, I'm worried that measuring errors might affect the result too much if I go for gauge pressure sensors.
Pipes are in PVDF plastic but PTFE also works.
Anyone have an idea?
