L
I have faced the following problem. I'm not an expert of PID tuning but i have programmed both allen bradley slc500 and siemens S7. the FB47 seems to work only in the OB35. When i used the FB 47 in an FB or FC it doesn't work or at least react as a proportional controller. I have tried hundreds of configuration (changing P,I,D) but the only parameters which change the response is the Proportional. (i have enable the I and D components). The situation change completely when i use the OB35 where all the components have effects on the response.
thanks a lot for any help
ciao
luca
ciao
luca
