P
There are some situations when my PlantScape system doesn't switch to backup server automatically.
The first situation when I saw that my PlantScape system did not switch to backup server automatically was when I used the primary server for some Excel files and somehow the computer froze all the applications. The operator stations showed then some non-process values and the system did not switch to backup (even after a few minutes).
After this I made some more tests and I conclude following:
1. Any time when the active server freezes because any reason the system does not switch to backup server automatically. Someone has to do it manually. “Freeze” a mean to say when the computer doesn’t respond and the only way is to restart it by its front panel button. I can get a frozen server by malfunction of a DOS program or an Excel file
2. If I stop some services on the primary server (RSLinx for example) I get some non-process values on the operator screens and I have to do manually a “fail over to backup”.
3. Same thing if I disconnect the ControlNet cables from the primary server.
4. In all other cases that I could check the automatically switching to backup is done in less then 30 seconds.
On TDC3000 the redundancy is such a reliable thing but here on PlantScape I don’t feel the same.
So, is it normal or does it happen only on my system?
Thank you for any information regarding my problem.
