HI guys new to this site, I just starting working with plcs and have a question. I have two AC Torque motors (advantage is these ac motors provide a constant torque at stall without burning out the motor). I need to control the torque automatically with a plc (the work with tension sensors to provide the proper amount of torque to keep constant tension in the spooling fiber). In order to control the motors you need to vary only the voltage supply; i.e. variable frequency drives will not work. Someone mentioned an analogue triac output but I have not seen any sort of variable voltage ddrive that can connect to a plc. Does anyone have any solutions. I have to use these AC torque motors, I think servo motors are way beyond my budget.
Okay
There are two fiber spools each with a mounted ac torque motor. The spooling fiber is being spooling onto a spooling fiber for a particular length. The fiber is then de-spooled from both spools and cut in as its being pulled from both spools. The machine is only in motion about a third of the time but a certain amount of tension needs to be applied even in this stall mode in order to prevent tangles (its a wavelength shifting fiber and is very expensive). Hence the reason for ac torque motors to supply torque to create this tension. That same level of tension needs to be regulated while the machine is in motion (via tension sensor inputs to the plc) Essential the program logic will ideally take tension level inputs and send a vary ac output voltage to the motors (PID) for continuous tension control. thanks again. Oriental Motors did not have any suggestions besides triacs, but I believe those vary the frequency.
tenbaum
Okay
tenbaum
