I'm trying to find a PLC or an A/D-D/A module which can give me a digital to analog output (Voltage 0-10V) of 24 bit resolution. This is for automating a Hydraulic Force Press which reads from 0-60,000 lbs in 1 lb increment or better. Hence commonly available 16 bit (65,500 counts) input/output is not enough. Please advise if any off the shelf products available which can be programmed using windows. Thank you.
Amith.
Amith.
