Hello
I am just wanting to know if there is an application out there (command line based is pref) which you can specify a PLC IP address and the holding registers you want to read, and the number you want to read - and for it to output the contents to a txt file or similar.
I then want the ability to do the reverse and output the contents of the file back to the same PLC.
Basically a backup and restore application for set registers on a Modbus PLC - which an be triggered from somewhere like a SCADA for backup of data prior to planned maintenance or even periodically in case of hardware failure.
If there is anything that you know of, can you please let me know.
This will be talking to Schneider PLC's, specifically the M340 however it will be suitable for any modbus TCP based PLC.
