F
Are there any issues that one needs to keep in mind when programming a PLC that’s supposed to be connected to an existing SCADA server (FIX)?
In this case, a PLC system is bought from one vendor, and the integration with the FIX-server is bought from another. Therefore, I would highly appreciate if you could tell me whether there are any specific requirements, which I should make on the supplier of the PLC system to make the integration easier.
