I'd like to use an AB MicroLogix 1400 PLC to control some devices over RS-232/ASCII. I'm looking at EtherNet/IP in combination with some sort of gateway to achieve this.
I don't have any experience with EtherNet/IP, so any information on this would be greatly appreciated.
The devices that I wish to communicate with are, for all intents and purposes, closed systems that do not support any other industrial protocols. They do however process and send ASCII commands/messages over an RS232 port.
The PLC I have to work with is an AB Micrologix 1400 that supports EtherNet/IP.
Is it possible to connect my ASCII devices to some sort of gateway to enable the PLC to control them and to receive/respond to messages?
Are the MicroLogix's EtherNet/IP capabilities sufficient for this sort of task?
Thanks,
Chris
Thanks,
Chris
