Hi everybody, as may be able to understand, I am a complete newbiee in the field of automation and also a new user of this forum: I am working on a project on which I have to use a Laser Distance Sensor(InfraRed, specifically the Wenglor PNBC006 High-Precision Laser Distance Sensor from WENGLOR); this sensor will be mounted on a slider controlled by a stepper motor; this slider will be on top of a car tyre at a fixed distance and basically the laser sensor needs to measure the distance from the tyre tread while moving over it, from one side to an other. The tyre will be mounted on a motor and spinning with a fixed rate.
My question is, how do i get readings from the sensor to the raspberry pi?(I HAVE TO USE THIS MICROCONTROLLER). I've never used Rasp Pi with industrial sensors before and from the datasheet the Laser has connection socket of 8 pins and I have no clue on how to wire it up to the RASPBERRY Pi!! I really appreciated if you could point me in the right direction and explain to me what I need to do. I've been searching on the web and couldn't find anyone else who didi this before me nor anything else similar! I came accross a lot of new terms and wordings that were unknown to me till few days before typing this.
on the datasheet it says that the sensor has an ethernet tcp/ip inteface, but cannot see anything related to this at least from the drawings...
here I attach a screenshot
Please help me out since I've been hunting and searchin online on how to connect it to the raspberry pi and couldn't do much, actually nothing.
THANK YOU IN ADVACE FOR ANY ADVICE OR HEL OR ANY INFORMATION THAT COULD POINT ME IN THE RIGHT DIRECTION.
