Pls help me,Slave ID of RS485 was changed
incase if the id was chnaged and forgot what is the id or the ID was changed by wrong way . Does the sensor have the way to restore to factory parameter
No, there are no devices that remember setting changes. The device might have some means of resetting All parameters to factory default settings, but there is no device I've ever run into that just resets the slave node ID number.
can you explain the splution about reset the slave node ID number, thank you so much
No, I can't. That's your job to find the document for your device and read it to find out whether there's a reset-to-defaults function and how such a function is implemented. It's the cost of ownership.
