portable flow meter
L
Larry Le Francois
Looking for a portable non intrusive flow meter for performing air audits. On large plant sites we need to individually measure the flow from different pipe lines of compressed air in the 100 psi range. Must be portable, easy to set up and reasonably accurate.
David W Spitzer
Larry,
You might want to consider an ultrasonic flowmeter.
I am putting the final touches on "The Consumer Guide to Ultrasonic and Correlation Flowmeters". It can be backordered at http://www.isa.org. I hope to have it on the shelf within 2 weeks.
Also, I will be offering one-day seminars based on this and other Guides near New York City on 23-27 February. For more information, visit http://www.spitzerandboyes.com/seminarinfo.html.
Best Regards,
David W Spitzer
[email protected]
+1.845.623.1830
For air audits, an ultrasonic won't work. A better device would be a use of Air Velocity Meter (Kurz Instruments, Inc. USA) who can go upto 500 Deg. C temperature. This instrument will also give you temperature along with mass flow. A great instrument for its value.
If you need details contact me over email.
[email protected]
