H
Can gas turbine that driving a centrifugal compressor run while compressor trip? Is there a coupling between the turbine shaft and a compressor shaft? For example, if there is high high level in the compressor suction drum, normally compressor shall trip. Does also turbine should trip or not.
For solar gas turbine, we have Gas producer, Power turbine and the centrifugal Compressor. what happen if high high level in suction drum? Do GT will trip or only Compressor?
