Hello all.
I have been reading AB's manuals and I have found that with a series B Power Monitor you won't be able to read unless you use a CIP type message block. What is the difference between a CIP and a CSP type message block? Can I just use a 500 CPU Read type message block to pull the data across? The type of comm is ethernet as a side note so Ch. 1 out of the SLC.
Thanks in advance for any replies...
