I am facing a voltage drop problem while switching a 24VDC relay by an another 24VDC relay. (ie)
Coil of my remote relay is connected to contactor of my panel relay with a 5mts wire. Not a single relay is connected so but a group of such relays are wired through a D-type 25 pin connector. Once any of the relay is switched ON the voltage drops from 24V to 18V. The more no.of relays turned ON the more drop occurs. The voltage observed is almost 11V when all 16 relays are switched ON. All the relays are of the same type and rating (Coil current = 80mA). Can any one help me ?
