I have about 200 powerflex drives of varies models and have a problem when the inherent problem of Ethernet shows up; that being loss of communications means no way of knowing the status of the drive.
Some devices I use have built in watchdog bits that I can monitor from the PLC. Allen Bradley drives do not have this feature. Has anyone dealt with this issue and if so, how did you remedy the problem?
