- Zeros on the left hand side of the jw axis indicates that the system is minimum phase.
- Zeros on the right hand side of the jw axis indicates that the system is non-minimum phase.
- Zeros on the jw axis indicates that the system is 'marginally' minimum phase. The magnitude and frequency response of such a system indicates a phase shift of 2*pi rad between the input and output while the magnitude of the input/output response is 0db for a major part of the frequency range.
My Questions are as follows:
1. What is a transfer function without zeros at all referred to?
2. If the relative degree of a linear system is the difference between its poles and zeros, a transfer function without zeros has its relative degree = number of poles.
What does this mean in terms of the practical response of the system?
3. Is it preferable to have a system with left hand zeros or no zeros in terms of its transient response? Looking at the bode plots, no zeros seem to support a wide frequency response. However, at a certain frequency, the input is dramatically attenuated and the phase shift is undefined!
4. The zeros of a transfer function dictates wether its zero dynamics is stable. Zeros of a transfer function coincide with the roots of its zero dynamics. Does this mean that a system without zeros has no zero dynamics and therefore is advantageous when designing a controller?
Thanks,
Klaus
Thanks,
Klaus
