https://instrumentationtools.com/multiple-pumps-control-using-plc/LOOKING FOR PROGRAM TO CONTROL 4 LIFT STATION PUMPS FOR A UNI
Original poster seems not replying... Doing some efforts for no reply can be like pouring water on sands...Use 1 pump in and 1 pump out, both run by VFDs. Control the VFDs with PID loops. You should be able to keep the level fairly stable that way.
D | Is Droop Setting Fixed for Frame 5 GE Turbine When Machine Is Designed? | Power Generation | 2 | |
A | pre loop and loop checking | Process Control | 3 | |
E | Adding signal names to pre-vote display | Power Generation | 0 | |
D | Numa-logic PLC timer pre-set | Programmable Logic Controller - PLC | 1 | |
S | Petrocount transmitter pre amp | Sensors & Calibration | 1 |
