hi
i'm asking how to simulate for preloop from the field to Process Interface Bldg. (PIB) or DCS this instrument: the tools we been use was Hart Communicator 375, LC 100 Martel, Druck 300 DPI603, Ametek 7975 Hand pump, megger, TK3 and can you give a drawing the typical setup of each instrument to calibrator to simulate the preloop? i'm appreciate those who will help me. and how to use the calibrator to simulate the instrument?
H2s gas detector
combustible Gas Detector
Corrosion XMTR and Access Fitting CM, BEACONS, HORN
TRANSMITTER HART / ANALOG - Corrosion Transmitter
DP Flow Transmitter w/ ventury, Rotameter Transmitter, Analyzer Indicator Transmitter, Agar Level Transmitter, Vibration Transmitter, Intensity Current Transmitter, Magnetic Flow Meter, Remote Level Indicator, Remote Temperature Indicator, Temperature Indicator Transmitter, Analyzer Indicator Transmitter, Agar Level Transmitter, DP Level Indicator Transmitter, Vibration Transmitter, DP Level Indicator Transmitter, Temperature Indicator Transmitter
TRANSMITTER FIELDBUS
Corrission Transmitter Fieldbus
DP Flow Transmitter w/ ventury Fieldbus
Rotameter Transmitter Fieldbus
DP Level Indicator Transmitter Fieldbus
Guide Wave Radar Level Transmitter Fieldbus
Analyzer Indicator Transmitter Fieldbus
Agar Level Transmitter Fieldbus
Vibration Transmitter Fieldbus - FFVMS Trend master 2000/ Velocity Seismo Probe
Magnetic Flow Meter Fieldbus
Remote Level Indicator Fieldbus
Remote Temperature Indicator Fieldbus
Temperature Indicator Transmitter Fieldbus
Thermocouple Temperature Transmitter
RTD Temperature Transmitter
CONTROL VALVE
ON OFF Deluge Valve
Level control valve Fieldbus
Hand Control Valve Fieldbus
Temperature Control valve Fieldbus
Pressure Control Valve Fieldbus
Level Control Valve Fieldbus
MOV FF
AOV FF
SWITCH
Pressure Switch
Level Switch
Temperature switch
Flow Switch
Pig tail
H2s gas detector
CONTROL VALVE
ON OFF Deluge Valve
MOV FF
AOV FF
SWITCH
Pressure Switch
Level Switch
Temperature switch
Flow Switch
Pig tail
