I have a DP transmitter (yokogawa EJA series) that the low side of the sensor connected to a 1/2" tube that connect to a pressure repeater in the top of the vessel, and it measures pressure, units shown in the control room / DCS are in bar.
The questions is can i use pressure repeater for vessel level measurement? using DP transmitter that the H side connected to the vessel using 1/2" tube and the low side connected to a tube that connect to a pressure repeater? (must show %liquid level on DCS)
note that the previous transmitter (remote / diaphragm sealed) connected to the tank is broken. And because the fluid are corrosive and the temperature are around 100 degC (vapour). only the H side are made of tantalum and the L side is hastelloy. so i avoiding direct contact using pressure repeater.
also, can i use water as filled liquid in L side on wet leg configuration with the vessel temp around 100 degC?
*sorry for my english
