Hi
I'm configuring a WinCC V6.2 SP2 Server (Windows Server 2003 R2) for S7-fault tolerant system for 2nos of 414-4H CPU. The Server PC has two Siemens network cards CP1613 an S7 redconnect for switch over. The configuration is working as expected in the plant bus side. I have one client PC (WinXP SP2) for the server. In the terminal bus side Im using the onboard Ethernet port to connect to the client PC and Server PC. Both Server & Client are Dell Optiplex 755 desktop PC.
When Im pinging the client PC IP address from Server PC it is showing "Hardware Error". From the client PC I can able to ping the Server PC IP. Some times it is reverse also. I have uninstalled & reinstalled the driver of the onboard Intel 82566DM network card. After that I can able to ping from either side. But it is not consistent. After reboot again Im getting the Hardware error during pinging.
I wanted to know whether the CP1613 is conflicting with the terminal bus? Any settings to be done for the terminal bus? In the device manager I could see both CP1613 & Intel card are under Network adaptor category.
Kanag
Kanag
