Problem with Change of UCVF by UCVE
In our site the control system of gas turbine is mark vi and the controller type S are UCVF. There is one spare part with UCVEM.
when I replace only one UCVF by UCVE controller and downloaded Pcode and restart the system in VCMI Status LED Shows ON
and Error 57 Appear in Diagnostic Buffer of VCMI .
Would you please help me that can replace UCVE by UCVF and is it work properly?
thanks
My mail
[email protected]
thanks
My mail
[email protected]
Did you ever have read on OEM manual??
I have read one OEM manual, and here is following notes for the "Fault /Error code 57 in diagnostic buffer of VCMI:
57 Controller Sequencing Overrun Too much application code used in controller. Reduce
the code size.
Did you ever try to reduce the code size??
Do not hesitate to let us know what you did and we can support you as best as we can !
Controls Guy25.
Dear Javad ,
when you change ucvf to ucve which fash card you are using ?
is that that same in ucvf or new for ucve ?
did you bulid application code ??
I used 16 mb flash the same as used in UCVF
and after that I used 128mb flash to
In both try Error 57 appear on VCMI and we don't want reduce app code and delete some logic
Would you pls help me to solve this problem any way?
Replacing a Controller
! To replace and reload the UCVx
1 If a controller has failed, the rack should be powered down, and all cables
disconnected from the controller board front.
2 Remove the controller and replace it with a spare controller.
3 Pull the VCMI out of the rack far enough to disconnect it from the backplane.
4 Connect the serial loader cable between the computer and COM1 of the
controller.
a. If the controller is a UCVB or UCVD, use the serial loader to download the
flash file system to the controller
b. If the controller is a UCVE or later, use the compact flash programmer to
download the flash file system. (The programmer is included in the service
kit)
5 Use the serial loader to configure the controller with its TCP/IP address.
6 Reconnect the Ethernet cable to the controller and power up the rack.
7
Use the toolbox to download runtime to the controller.
8 Use the toolbox to download application code, to permanent storage only, in the
controller.
9 Power down the rack.
10 Re-insert the VCMI into the backplane.
11 Power up the raK
the code size.
Controls Guy25.
I don't want delete logic and build again for reduce app code
Do you have any way to solve this problem
Or do you have way for reduce app code without delete some logic code?
As per my knowledge And experience you have to delete the files and build and download .
apart from theses i dint know the way to solve this issue .
and i wold like to ask you why you do no know dont want delete the old files ?
Dear Javad ,
Dear sir ,
I used 16mb and 128 mb flash for it and I change in hardware cpu from UCVF to UCVE and after that build app code again and download app.code and download my project.
Ok s
Ok you seems to want to play here... We will see who gonna win ..I am sure you will loose!
Adios , Hasta la Vista ,addio,別れ
Joking with poster's "avatar" thats pretty poor , and reflecting how your poor personnality is and sure how you Brain is lol !
Controls Guy25.
Dear sir ,
DID YOU DOWLOAD FLAS CARD ??
AND SERIAL LOAD SETTING ?
THIS FASH CARD WHICH USED IN UCVF CANT USE AS IT IS IN UCVE , I HOPE YOU DAON THE STEP ?
AND WHAT IS THE STATUS OF YOUR CONTROLLER NOW ??
can you explain me what all the step you done ..?
so that i can guide u thought the farther procedure .....or plz do this below once again and delete the old app code re build it and download ...
controller.
kit)
7
controller.
11 Power up the raK
