O
Hi, my name is oswaldo and I have a problem with the communication with a PLC siemens and PC ethernet network.
I have a ethernet network and i want to connect a plc siemens S7-300 with a CP-341 module to the ethernet network and through Step 7 intalled at a PC connected to the same ethernet network, I want put ONLINE the application.
I installed the CP-341 and assigned the IP address, from the PC connected to the ethernet network I make a PING to the IP addrees and I get a request from the PLC siemens, but when i try to connect with the step 7 i can not do it.
I do not if I need to intall a ethernet adapter or a ethernet driver in the PC.
Thank you.
Best Regards.
Oswaldo
Thank you.
Best Regards.
Oswaldo
