The network doesn't find tsx etz 510. I don't know if I have all features. How can I know the XWAY address? Can you give me example?
Thank you for your help.
you dont need the xway addess you need the ip address you can get it from the mac address of the module or you can use a cross connet cable to connect direct to the module and a snnifer like ethereal when you connect the module the tcp/ip protocol send a bradcast and the snnifer capture the ip and the mask then you change your own ip and mask to be part of the net of the module and by this way you can acces it using your web browser then you can change the xway address and you then configure the xip driver whit this address to acces the module via xway....
By default, the IP address from the factory is :85.16.xxx.yyy, where xxx is the second-last number from the mac address and yyy is the last number of the mac address. Configure your ethernet port to be on the same sub-net and hit the IP address with your web browser...
