I'am trying to control an ATV58 drive with Unitelway communication protocol from
TSX Premium PLC.
Acording to "Internal communication variables" user manual, suplyed with driver, I'm sending 07h for STOPing the drive and 0Fh to RUNing the drive in internal word W400 (as CMD control word ).
I use WRITE_VAR and READ_VAR to send command W400 (CMD) and to read status W458 (ETA).
In user manual is writen by a squence wich is to be follow to start RUNing the driver.
Q: Cold You explain me how exacly is working this sequnce.
Q:If I want to use "Force Local Mode" I'l have to stop the driver when I want to change between "local mode" and "serial mode"(?) or this change is not stops the driver if the RUN command is high in both modes?
Thank you.
Best regards.
TSX Premium PLC.
Thank you.
Best regards.
