I'm using Magelis XBTGT 6330, but I have some problems to download application via USB and Ethernet. It worked well earlier, but now it is damaged. While downloading newer application or installing Runtime (Runtime Installer) I obtained a kind of info:
"Failed to connect to the target machine"
or "The requested target node was not found in the token ring. (S7300400Series02)" on the touch screen of my Magelis.
The problem is that it does work with an application downloaded earlier but now there is no communication with it. I had this problem earlier and it finished with sending another Magelis to the producer. If you know other cures for this problem it would be great.
Thanks.
Thanks.
