Hello... I'm trying to connect a TSX37 to a SSE232-ST (serial to ethernet converter) on my intranet. I use a port redirector software (SERIAL IP V4.03) to set COM2 to the SSE IP address (and TCP socket).
( http://www.exemys.com/site/pages/english/products/serial_servers/SSE232-ST.htm )
I'm using PL7MICRO V3.4, Unitelway protocol driver V1.3 IE08 and unitelway configuration tool V1.0.
Only when i change TXRX param (on the driver configurator--->advanced options) from -1 (default) to 10, the PLC respond and i can both download, upload, turn to RUN or STOP. After 3 or 4 minutes the comm fails and it's imposible to reconnect. What i'm doing wrong? The cable=no 'cos sometimes connect... the SSE232 conf=no 'cos sometimes connect... When i can obtain information of unitelway params or uses like this? Really thanks in advance!!!
