Profibus DP to Modbus RTU Gateway
We need to read data from Profibus DP. So anyone can suggest reliable gateway to convert date from Profibus DP to Modbus RTU?
PT
PT,
what control system are you using? most of the time, you will have to bring it through the IO system, then the Controller. You could probably use a gateway in the controller or maybe up through the HMI.
Max
Hi PT,
there are many gateway products to choose from. look at prosoft technology, hilscher, rta automation, hms anybus. good luck.
GAK
I
Ikhtiander -
