I am trying to get a higher speed communications between two different DCSs (Delta V & Moore APACS). Moore is limited to Profibus, Modbus, and OPC interface for communications. Delta V has multiple platforms of communications. We do not want to use an OPC interface because of inherent fault due to a PC. Modbus is limited in speed to 19.2kbps. So with limited experience in Field Bus we figured the PROFIBUS with speeds up to 14Mps would be just the ticket.
Wrong assumption on our part. Both the Moore APACS and Delta V DCSs Profibus interface is PROFIBUS DP and both units must be a master unit.
My question is can MASTER to MASTER communictions be accomplished on a MULTI-MASTER Proifbus node without any slave devices.
Has anyone attempted doing the above? Can master to master comms over Profibus DP be accomplished?What hardware issues and software/programming issues did you run into?
Mark
Mark
