P
HI,
I have a 315-2DP and a ET-200M configured and running fine. I have recently had to hook a C7 unit on to the same network.
My problem is: can I monitor PAW's on the C7 from the 315-2DP without putting the C7 into my Hardware Profile (I do not have access to the code for the C7 as it is from another company). Even if I do put a C7 in the Hardware profile can there be direct data exchange or will I have to use a telegram to send information back and forth. Thank you for your help.
