today i got the task of starting up a machine that has not ran in years. it has a trol t6 controller in it and it needed to be programmed. well i never had to do this before and the instructions were as plain as mud. anyway the program was not in page a and something was in page c but nothing in the other pages. and in my ignorance i managed to delete the programs in the pocket programmer.
i tried to place a program in it and i did get one but i need to put lines in the program to make the cylinder open when a safety sensor is broken. i tried all i know and could not get it.
i have 3 inputs and 3 outputs input 1 is the finger input 2 is a part present and input 3 is the cylinder that presses one part int the one that was place for part present. i got it to see the part and to go when i press the finger and to press the parts together but when i break the safety beams when the press is in motion it continues to close. if i have the beam broke before i press the finger switch it will not close
output 1 is the part clamp 2 is a small cyline to hold that part some more during the press from output 3
i look for input 3 to be on and then 2 to turn on then 3 to be back on then 1 to start it then 3 to be checked then 3 t be on again then i turn on output 1 then 2 then 3 and wait 2 seconds and then turn 1-2-3 off. i have put checks in before input 3 and output 3 and compares and turn on and off and just about everything else in after output 2 closes and i still can't get the mace to be safe.
does anyone have a program that will do this i can use. or maybe tell me where to insert the correct safety limes. i would really the complete program from line 1 to the end. thanks for any help.
