We have a converter "Prolinx". We want to convert the data between a Premium PLC (Modbus TCP/IP) and a SCADA (Serial IEC).
We have problems with the correspondence of the directions of the "Premium" PLC. In Prolinx we can only configure directions as a number, I mean:
The registers in Prolinx are defined like this:
0xxxx digital output
1xxxx digital input
3xxxx analog (register) input
4xxxx analog (register) output
And when you write the beginnig direction of the correspondent register, prolinx can't let you to put the direction as in the PLC (%MW1000 for example).
We want to know how the correspondence of the direction between Premium PLC and Prolinx is.
Thank you very much,
Ainara
1xxxx digital input
Ainara
