I have MVI56E-MNET card Controllogix 1756L73S processor and Mitsubishi TS1070i HMI. HMI came pre-set and with following info that needs to be entered into Modbus card
From PLC to AGV:
Address ID 32769 16bit R/W
Address ID 32770 16bit R/W
From AGV to PLC
Address ID 33280 16bit R only
Address ID 33281 16bit R only
Address ID 33282 16bit R only
Address ID 33283 16bit R only
Address ID 33284 16bit R only
Address ID 33285 16bit R only
My setting is as follows
# Enable Internal Address Poll Interval Reg Count Swap Code Node IP Address Serv Port Slave Address ModBus Function MB Address in Device Comment
1 Yes 3000 5 2 No Change 192.168.0.200 502 1 FC 4 - Read Input Registers(3X) 2768 #
2 Yes 3002 5 6 No Change 192.168.0.200 502 1 FC 4 - Read Input Registers(3X) 3279 #
3 Yes 2000 5 2 No Change 192.168.0.200 502 1 FC 3 - Read Holding Registers(4X) 2768 #
I have difficulties receiving and sending info to touch screen and wondering is if there is a quick solution for this.
From PLC to AGV:
From AGV to PLC
