We just installed a Modicon 174 CEV 200 Modbus Plus to Ethernet Bridge for use in programming several Modicon PLCs at a customer's site. They are using Proworx NxT v2.2. We are able to connect and go online with several of the PLCs (Quantum 213, 984B, Compact 145) through the bridge, but have one major issue.
Whenever we try to SEARCH for an address online Proworx goes out to lunch. We end up having to reboot the machine. They are running Nxt on Windoz XP, which isn't the best setup to begin with. So I tried from my laptop which has Proworx32 v1.11 and have the same problem (except I'm able to kill Proworx32 without rebooting).
We can do all required functions (including searching) when connected via MB-MB+ bridge (BM85) although it's slow and we are then "leashed" to within 50' of the BM85.
The setup of the 174 CEV 200 is pretty simple and there are no obvious settings that would point towards this problem. We did not even need to setup any routes to make the online programming work, which is nice. However, the inability to search the program online will be a show stopper.
Any input would be appreciated.
Thanks,
-Brad
Thanks,
-Brad
