I'm using the PTO of a AB Micrologix PLC as the master encoder signal to slave a couple of 1-1/2 axis servo drives to. The pulse frequency from the PLC can be up to 20KHz.
I'm looking for a (preferably small, DIN-rail mount) signal conditioner/converter to take that single 24V pulse train and output a differential quadrature encoder-type signal (at TTL levels).
I've found some things that are close, but not quite what I'm looking for. Anyone else ever use somthing like this?
Thanks,
Matt
Thanks,
Matt
