R
Hello every-body
I wonder if somebody can give me information regarding PWM control of hydraulic valves.
I use 22ohms, 24volts magnets, 120mH. Which is the best method of controlling those valves. Low frequency (100Hz to get the ripple) or using higher frequency and the add the ripple to the control signal ? Which is the best frequency if I
use higher? Is it possible to generate this signal on a PWM output on a Texas DSP TMS320LC2404A ? . Have anyone experience of EMI problem using higher PWM frequency and long cables between control system and valves, over 10m, I need to be under class B ? . And a book about this subject, did anyone knows a good
one ?
Regards Richard
one ?
Regards Richard
