N
Hi all,
I have to control a temperature (3 channels, J type, 30 ~ 60oC, Solid State Relays). I can use a PID control (PLC’s PID Function or a simpler one) but the existing PLC has only relay type outputs (not transistors nor analog outputs).
Any idea how to build a “hand made” PWM in combination with the PID MV output? I need a large cycle time (some seconds) because the relay contacts.
Thanks in advance
Nikos
P.S. I can’t use external temperature controllers, I have to integrate the temperatures in a HMI – recipe system.
Thanks in advance
Nikos
