(This is paraphrased from the customer's email to me.)
On page 82 of the 890_USE_101_00 manual it indicates that the system is grounded through the RIO head processor. If the connection to the RIO head is removed, the ground is lost, but there are no signals being passed. What, then, are the consequences, if any, of not having the ground
block in the RIO line? What are the safety concerns mentioned in the write-up? When should grounding blocks be installed? Could the ground in the RIO together with the ground block create a ground loop?
