I my plant we have take shut down of gas turbine 6B after that turbine came to zero speed and cool down started and had four cycles only after that we came alarm of ratchet trouble again after we checked 20cs find ok and we waited for wheel Space temp 100 deg upto then we kept running aop continuouly and again we manually jogged but 88HR pump developing pressure 90kg/cm2 we checked any leakages found no at that lube oil header temp ltth 54deg and again when wheelspace temp reaches 36 deg we manually and that time ratchet happens at that llth is 27deg and we observed that cycle is time is more in forward stroke aprrrox cycle time take 40 sec and slowly it got decrease.can u explain the reason.(while ratchet is not happening that time we have checked current of 88HR found 9amps but its flc is 6amps).we found 88HR function by disengage the clutch it found ok.
