E
<p>Marcelo,
<p>Here is a routine that I use.
<pre>
static unsigned short int vmbcrc16 (unsigned char *bytp, int count) {
#define VMBPOLY 0xA001
unsigned short int crc = 0xffff;
unsigned short int temp;
int i;
int j;
* Checksum the buffer
for (i = 0; i < count; i++) {
crc ^= bytp;
* Use all 8 bits in the byte
for (j = 0; j < 8; j++) {
unsigned short int one = crc &1;
* Shift right one bit
crc >>= 1;
* If the previous LSB was a one XOR with the polynomial
if (one)
crc ^= VMBPOLY;
temp = (crc >>8) &0xFF;
crc = ((crc &0xff) <<8) | temp;
return(crc);
</pre>
<p>Eugene Zharkov<br>
Vista Control Systems, Inc.<br>
http://www.vista-control.com
<pre>
int i;
int j;
crc ^= bytp;
crc >>= 1;
if (one)
crc ^= VMBPOLY;
return(crc);
</pre>
