We are trying to develop a small Application which suppose to read data from several Endress & Houser F83 Modbus flow meters using RS485. We have success with device construction and its communication and data acquisition properties stored in the DB. Also the construction of Modbus commands via DB is done. The problem is when we try to read a target register, (2017 - Temperature) we fail.
According to the Description of Device Functions of the "Proline Promass 83 MODBUS RS485 pdf" we have to build the following command to the device:
1. DeviceId
2. FunctionCode
3. StartRegister
4. Register count to read
5. CRC
And have to receive a float represented by 4 bytes (2 registers).
The number of register responsible for Temperature is 2017 (information in decimal numerical format) according to the specs.
The deviceId - is 48
The register count - 2
CRC is being generated.
So the final bytes array that being written to port looks like
[48] - SlaveId
[4] - Function code
[7] - MSB
[225] - LSB
[0] - MSB
[2] - LSB
[36] - CRC
[168] - CRC
The response we get looks like:
[48] - SlaveId
[4] - Function code
[4] - Bytes count (According to device specs)
[225] -MSB
[225] - LSB
[225] - MSB
[225] - LSB
[218] - ?
[211] - ?
These response bytes are not the bytes that we suppose to get.
P.S. Using the original manufacturer software we are able to get correct values. So it is 100% clear that device is OK.
Where do we go wrong?
Any help is appreciated. Thanks in advance!
1. DeviceId
2. FunctionCode
3. StartRegister
5. CRC
[48] - SlaveId
[4] - Function code
[7] - MSB
[225] - LSB
[0] - MSB
[2] - LSB
[36] - CRC
[168] - CRC
[48] - SlaveId
[4] - Function code
[225] -MSB
[225] - LSB
[225] - MSB
[225] - LSB
[218] - ?
[211] - ?
