I have a ControlLogix 5000 series processor running ControlNet. I want to measure the current useage of fuel valves on an industrial turbine engine. I have installed several "shunts" inline of know resistances (0.1 ohms) and would like to measure voltage drop across this resistor to calculate amperage use on various parts of the fuel system while in use. A reading of 10mV equates to 1A. This is a 24vDC fuel valve system. I have spare analog input modules (1794IE8). This module has a common 24vDC backplane. I want to measure a value of less than 1 volt drop but the shunt voltage is 24vDC. How can I do this? Is there another module (ControlNet) that I could use to do this? Thanks for any feedback.
