I have a digital weighing scale I need to connect to the PC using RS232 communication port. Every time I weigh an object, automatically the result/weight will display in the the textbox control in Visual Basic Application that I made. I need your help.
I use to receive data via a timer for continuous looping sequence output to a textbox. Things do goes bad, as it flicking all the way. I using a indicator from AD series which read data from load cell of a truck weight bridge. It there's any way to stop this flicking without effecting the continuous loop?
please help me vb6 vb2005 vb2007 vb 2010
any thing no problem i want the solution in another way is also no problem
