Does anyone know of a sensor that will measure relative humidity (0-100%) in a vacuum (-1.25psig)and 800 degrees F? The highest rated temp. I have found is around 400F. It also needs to have 4-20mA output and local display. Thanks
R | Relative humidity in compressor inlet air | Power Generation | 10 | |
Z | Effect of Relative Humidity on GT Output | Power Generation | 2 | |
S | Gas Turbine Efficiency/Power Output vs Relative Humidity and Specific Humidity | Power Generation | 15 | |
S | Relative humidity sensor | Sensors & Calibration | 1 | |
H | relative humidity in curing oven | General Automation Chat | 0 |
