Remote Access Options
Jeremy Pollard
I am writing a column on Remote Access methods, concerns, and options.
Is Teamviewer, LogMeIn, VNC, and RDP 'good enough'??
Is using a remote laptop and a VPN with a password good enough?
Is there any need to authenticate the device or user that is logging into the network?
Is/are the process(es) that is/are available to the network critical enough to require a higher remote access security requirement than 'normal', or do we simply not care?
Thank you in advance for any and all replies!!! Much Appreciated
Cheers from: Jeremy Pollard, CET The Caring Canuckian!
Crisis, necessity, change
www (dot) tsuonline.com
Control Design www (dot) controldesignmag.com
Manufacturing Automation www (dot) automationmag.com
James Ingraham
Generally, no. Certainly not direct VNC and RDP. Teamviewer and LogMeIn are perhaps a bit better. Leaving RDP open is asking for trouble. VNC is even worse; its record on security is pretty bad. Using port-forwarding in a router for known protocols is not considered good practice.
Maybe. A combination of a VPN with RDP might be better than a direct connection to machine controllers. That way, at least the controller isn't directly tied to the Internet, and there's another layer of security. However, it requires a dedicated PC, which introduces a potential weak point, and might have to be shared by people needing remote access. VPN straight to the controller is what I see most of. VPN to RDP is second. I've yet to see Teamviewer or LogMeIn.
Definitely at least the user needs to be authenticated. Device would be nice, but it adds a layer of impracticality. VPN already requires a user. I have seen a two-factor authentication with a time-limited code to allow the user to log in to the VPN, which is away to do device authentication.
There are absolutely some applications that are critical and should have more security. I like the two-factor authentication. I also like a site-initiation requirement, where the VPN is off unless a key is turned. The only downside on that one is the possibility that the key never gets turned to the off position.
I really hope that the security for remote login to nuclear power plants, power generation in general, petrochemical, etc. are at LEAST a VPN within a second requirement.
-James Ingraham
Sage Automation, Inc.
Jeremy Pollard
Thank you sir!!:) appreciate your feedback...
