N
We require a solution for monitoring the fuel level in tanks remotely. It should be done via GPRS. We require a fuel tank level sensor,an impurity sensor, a temperature sensor and need to hook up two binary sensors to the solution.
We require the following capabilities
-Analog signals from multiple sensors (fuel tank level , temperature,2 other binary alarms)
-A2D converter
-GSM Module
-Storage around 2 GB (if possible)
-Scheduled transmission of results to a web server via GPRS(every 5 minutes)
-Triggered transmission of results to a web server via GPRS
-Updates can be triggered via SMS from the web-server. Updates will be done via GPRS.
-Periodic NTP synchronization with the web server. ( results of the sensors will be transmitted with time stamp)
-Software to an external micro-controller continuous communication. If there is no heartbeat from the GSM Module's Software to the external micro-controller, micro-controller should be able to RESET the GSM Module.
-A webserver is required that can consolidate the date from more than 500 sites and generate reports.
Kindly propose a solution.
-Regards,
Nash./
PS (please mail directly at [email protected])
-A2D converter
-GSM Module
-Regards,
Nash./
