Hello
Need your suggestion :
I will replace 3/3 way center closed hand lever valve , I found that this valve difficult to find in market.
I will modify the 4/3 center closed hand lever valve by closing the output port no.2 so that the only output port is port no.4
Is my method allowed so that my 4/3 way center closed hand lever valve becomes 3/3 way center closed hand lever valve?
please help with the explanation
thank you
thank you
