K
Hello Everyone,
A ball Valve (mechanically operated) is been installed in LPG line. I have to install LPG leak detector on the same line. Leak detector output 4-20mA. If any leak sensed by leak detector the Valve should be closed.
is any possibilities to change ball valve to control valve without removing its flanges?
Kindly suggest what are all the possibilities of fixing control valves.
