G
Dear All.
We have the spare old control valves which we want to reuse for our new project. I want to know how to select the old control valve for new requirement.
e.g.New required conditions:
Max. Flow rate= 1500 Kg/Hr.
shut off press.== 4 kg/cm2
Delta P== 0.2 Kg/Cm2
Line Size== 25 mm
Liquid sp.gr== 0.895
Operating Temp.==40 °C
& I have a old control valve
Size==25 mm
Inlet Pressure== 4.5 Kg/cm2
outlet press.== 4.2 Kg/cm2
CV stamped on it is ==4
Can i utilize this valve for the new conditions. I want to do this for almost 20 control valves. I would like to know what are the parameters to consider for retrofitting of old control valves for new conditions. Thanks in advance!!!!!
Line Size== 25 mm
Size==25 mm
