I am currently confused on the best means of rotating 2 gearmotors. I have built an astronomical dome and have mounted 2 1/15 hp diagonally opposite each other. Each motor has 4 leads each (2 leads for line/2 leads for connections). The problem is that each set of wires per motor must flip/flop in parallel together in order to achive the correct CW/CCW rotation for both motors. I have tried using a 3pole doublethrow paddle switch 110V,15A but this dosen't seem to work. I was told I'll need to use 2 pushbuttons,1 for forward other for reverse. Also need 4NO/4NC set of contacts plus 1 each 120V coils. This is supposed to do the trick. I am not a control wiring genius so some really good wiring diagrams would be nice. Any help and advice would be greatly appreciated. Thanks David.
