Hey guys, after some ideas on a fault finding situation I have with a dp pressures tx
in simple I have a signal output from the transmitter, 8mA which is proportional to the pressure being put on it but I get a zero reading on the scada display of the transmitter
I have checked and tried-
Confirmed all wiring
Checked fuse
Checked voltage 24v
Checked all impulse lines and valves open
Checked polarity
After any ideas and opinions on what I could have wrong (thinking it could be a simple thing I’ve just over looked) a zero and span Calc has been done on it a month ago apparently and a fuse was blown
thanks
Checked fuse
Checked voltage 24v
Checked polarity
thanks
